[Qgis-developer] Re: [Qgis-user] qgis 1.6 crashes
Giuseppe Sucameli sucameli at faunalia.it
Mon Nov 29 12:25:21 EST 2010
On Mon, Nov 29, 2010 at 6:08 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Not sure how to get the list of plugins.
just run: ls ~/.qgis/python/plugins
alobo at HPepito:~$ qgis
> Python support ENABLED :-)
> Loaded : Geoprocessing (package: geoprocessing)
> Loaded : MapServer Export (package: mapserver_export)
> Error:
>        GDAL Error 4: `/media/FREECOM_HDD/VGT/SM/untitled folder/subs.bil'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> Segmentation fault
> 2010/11/29 Giuseppe Sucameli <sucameli at faunalia.it>:
> > Hi Agustin,
> > On Mon, Nov 29, 2010 at 1:36 PM, Agustin Lobo <alobolistas at gmail.com>
> wrote:
> >> I think it is the gdal tools, as this is what I get on the console
> >> after the crash:
> >> Loaded : OpenStreetMap plugin (package: osm)
> >> Error:
> folder/subs.bil'
> >> Error: use of NULL environment is defunct
> >> During startup - There were 16 warnings (use warnings() to see them)
> >> *** stack smashing detected ***: /usr/bin/qgis.bin terminated
> >> Segmentation fault
> > I'm pretty sure that the crash is not due to GdalTools.
> > In fact GdalTools doesn't load anything since the user clicks on one of
> the
> > tools in
> > the Raster menu, instead seems that a plugin tries to load a .bil file
> from
> > an invalid
> > (maybe hard-coded) path...
> > The "GDAL Error" message is printed by the libgdal, not the GdalTools
> plugin
> > at all.
> > BTW, can you send us a list containing the installed plugins?
> > Cheers.
> >> gdaltools are not there when I start with qgis --noplugins
> >> but cannot uninstall it if I start normally,  as it comes now bundled,
> >> so I cannot fully test.
> >> Agus
> >> 2010/11/29 Agustin Lobo <alobolistas at gmail.com>:
> >> > Has to be that, as the crash does not occur if I start qgis with
> >> > qgis --noplugins
> >> > I'll ty to identify the offending plugin, any ideas?
> >> > Agus
> >> > 2010/11/29 Jürgen E. <jef at norbit.de>:
> >> >> Hi Agus,
> >> >> On Mon, 29. Nov 2010 at 12:12:50 +0100, Agustin Lobo wrote:
> >> >>> No crash for vector layers, crash for raster layers.
> >> >>> The test consists of:
> >> >>> 1. Open qgis and load a raster layer
> >> >>> 2. Save the project and close qgis
> >> >>> 3. move or rename the raster layer
> >> >>> 4. Open qgis and open the saved project
> >> >>> 5. Crash
> >> >> Do have anything "unusual" installed?  Like custom build GDAL and/or
> >> >> plugins
> >> >> other might not have?
> >> >> Jürgen
> >> >> Jürgen E. Fischer         norBIT GmbH               Tel.
> >> >> +49-4931-918175-20
> >> >> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> >> >> +49-4931-918175-50
> >> >> Software Engineer         D-26506 Norden
> >> >> http://www.norbit.de
> >> >> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
> >> >> mbH
> >> >> Rheinstrasse 13, 26506 Norden
> >> >> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> >> >> _______________________________________________
> >> >> Qgis-user mailing list
> >> >> Qgis-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Giuseppe Sucameli
> Qgis-developer mailing list
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101129/c7828d47/attachment.html
