[Qgis-developer] thanks for the gpsd support!
Jürgen E. Fischer jef at norbit.de
Thu Oct 7 15:40:05 EDT 2010
Hi Giovanni,
On Thu, 07. Oct 2010 at 20:08:52 +0100, Giovanni Manghi wrote:
> it seems that with the garmin_gps kernel module loaded the connection
> via gpsbabel does not work anymore (at least on Ubuntu), but gps tools
> work using /dev/ttyUSB0! this should be documented.
Not really.  The gps tools uses gpsbabel.  gpsbabel can access the garmin
directly via usb w/o a special kernel driver.
The garmin_gps module provides a /dev/ttyUSBn device for the garmin.  At the
same time is blocks direct usb accesses to the GPS.  So when the module is
loaded, gpsbabel cannot be used with "-f usb:" anymore.
However gps tools/gpsbabel apparently can use the /dev/ttyUSBn device to access
the gps.  I just downloaded waypoints, routes and tracks from my hcx, which
garmin_gps (of kernel was loaded.  Although [1] claims that this is
"depressingly uncommon".
Still that probably won't work while gpsd is running.
[1] http://www.gpsbabel.org/os/Linux_Hotplug.html
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
