[Qgis-developer] Problems with Histogram tab in Raster properties
Benoit EXIGE benoit at exigesa.com
Sat Oct 16 05:19:05 EDT 2010
Hi Tim,
Many thanks for looking at that.
Regarding the NaN I will have to check because I think one of the
raster I've used (geotiff) had its NaN set to 0 and the histogram was
showing a spike at 0. But it could also be due to the Z-axis not
showing real values!
Cheers,
Benoit
On 16 Oct 2010, at 0:31, Tim Sutton <lists at linfiniti.com> wrote:
> Hi Benoit
> On Thu, Oct 14, 2010 at 9:51 AM, Benoit de Cabissole <benoit at exigesa.com
> > wrote:
>>  Hi,
>> A) In release 14370 the histogram tab of the raster properties window
>> has a problem:
>> The histogram is not displayed the second time the 'histogram tab' is
>> clicked.
>> E.g.:
>> 1 - open the raster properties window
>> 2 - click on the histogram tab
>> 3 - histogram is computed and displayed
>> 4 - click on any other tab
>> 5 - click on the histogram tab again
>> 6 - blank screen!!
>> On WinXP - OSGeo4W dev installation
>> Can someone replicate the problem?
> Ok I could replicate that. Will fix.
>> B) And keeping with the histogram, three comments/suggestions:
>> - Could the NaN be excluded from the histogram?
> According to the fine folks on #gdal (EvenR): "the pixels whose value
> is nodata are excluded from the stats" - note that this is only the
> nodata value considered by gdal - which isnt aware of any additional
> nodata values you may have specified in the transparency tab.
>> - Could the X-axis numbers reflect the actual colour values instead
>> of a
>> fixed 0-300 range?
> Yes I am going to do this.
>>   Note that the X-axis of the histogram is spread on colours values,
>> thus the displayed X-axis numbers are meaningless
> Right above should fix that.
>> - Could it be possible to add a zoom function on the histogram?
> I believe so - I will have a play and see how easy that will be.
> Thanks for the feedback!
> Regards
> Tim
>> Best regards,
>> Benoit
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
