[Qgis-developer] Qgis 1.5, python 2.6 and modules error with 32 or 64 bit architecture
Luca Mandolesi mandoluca at gmail.com
Mon Oct 18 10:11:46 EDT 2010
Sorry William, I'm stupid! I didn't understand I need only to open the file
info of Qgis app!
Now I don't receive the error about 32-bit mode.
Thanks a lot!!!
Luca
On Mon, Oct 18, 2010 at 4:02 PM, Luca Mandolesi <mandoluca at gmail.com> wrote:
> On Mon, Oct 18, 2010 at 3:31 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
>> On Oct 18, 2010, at 3:27 AM, Luca Mandolesi wrote:
>> > Hi,
>> > under mac os x I cannot use somes plugins with qgis 1.5 because I
>> receive this error:
>> > ImportError:
>> /Applications/QGIS_1.5/Qgis.app/Contents/MacOS/../Resources/python/pygraphviz/_graphviz.so:
>> no appropriate 64-bit architecture (see "man python" for running in 32-bit
>> mode)
>> > ImportError:
>> /Applications/QGIS_1.5/Qgis.app/Contents/MacOS/../Resources/python/matplotlib/_path.so:
>> mode)
>> > I'm under mac os x snow leopard with python 2.6.
>> > How can I solve this problem?
>> How did you install pygraphviz and matplotlib?  Source? binary?  from
>> binary, I'm guessing that only 32bit builds are available.
> Hi William, and thanks.
> I've installed pygraphviz from source (I found also Qgis don't allow
> pygraphviz to find graphviz, and I must to add a simple hack to make to work
> inside qgis) and matplotlib from easy_install.
>> You could force all of Qgis to run 32bit: Get Info on the application and
>> check the box "Open in 32bit mode".
> I don't understand where find Open in 32bit mode.
> Under /Applications/Qgis/ Show Contents -> I found Info.plist
> I opened it and I add a string:
> Executable architectures
> and add Intel-64 bit
> but nothing change.
> I think I need to allow Qgis to allow the 64bit python modules....
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20101018/954057ad/attachment-0001.html
