[Qgis-developer] linker error [undefined reference] while compiling qgis-1.5.0
Jürgen E. Fischer jef at norbit.de
Thu Oct 21 09:17:02 EDT 2010
Hi Ameet,
On Thu, 21. Oct 2010 at 18:22:25 +0530, ameet chaudhari wrote:
> The compile process of qgis seems very painful. After encountering and
> solving numerous errors during Makefiles generation [CMake], now hit the
> block at compiling. Just solved an issue, and then linker errors show up!:
On Windows that is, if you use MinGW.  The "official" builds use OSGeo4W
dependencies and Visual C++, which doesn't have the problems you have hit.
The MinGW port is pretty much unmaintained.  As is the build documentation -
checkout ms-windows/osgeo4w/package.cmd for "instructions" how to build with
Visual C++.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
