[Qgis-developer] Re: Raster layer display control from Plugin
JP Glutting jpglutting at gmail.com
Sun Sep 5 10:52:25 EDT 2010
Ok, I figured this out. It was as simple as:
resultsLayer.setContrastEnhancementAlgorithm(QgsContrastEnhancement.StretchToMinimumMaximum)
That computes the min and max, and stretches the grayscale (to black and
white for boolean rasters).
In the mean time I was futzing around with:
       * band = resultsLayer.bandNumber(resultsLayer.grayBandName()) *
*        minVal = resultsLayer.minimumValue(band)*
*        maxVal = resultsLayer.maximumValue(band)*
and
      *  resultsLayer.setMinimumValue(band, minVal, generateLookupTableFlag)
*        resultsLayer.setMaximumValue(band, maxVal, generateLookupTableFlag)
but it turns out that  *resultsLayer.**setMaximumValue(band) *returns the
theoretical maximum (255) rather than the real maximum (1), which is not
what I wanted. You can get the correct value with
*        maxVal = resultsLayer.bandStatistics(band).maximumValue*
However, it says that calling bandStatistics is very CPU intensive, since it
also calculates a lot of other stuff. As it turns out, the
StretchToMinimumMaximum algorithm seems to calculate the minmax anyway, so
none of that is needed.
My big mistake, as I was rushing through this, was to confuse extent and
values, as I was trying to copy from a tutorial and wasn't paying close
attention. Once I figured that out, it was easy.
On the other hand,
*resultsLayer.setColorShadingAlgorithm("PseudoColorShader")*
Doesn't seem to do anything at all. Strange.
Cheers,
JP
On Sat, Sep 4, 2010 at 6:35 PM, Benoit de Cabissole <benoit at exigesa.com>wrote:
>  Hi JP,
> I would suggest asking your question on the Qgis-developer list instead of
> this one.
> Below is what I've done to display a custom colormap on a raster. Could it
> be adapted to your problem?
>      # Display the raster with the selected colour table:
>      # - tell the layer to use a QgsColorRampShader function
>      theLayer.setColorShadingAlgorithm( QgsRasterLayer.ColorRampShader )
>      # - get a pointer to the raster shader function (QgsColorRampShader)
>      myColorRampShader = theLayer.rasterShader().rasterShaderFunction()
>      # - set parameters for the QgsColorRampShader function
>      myColorRampShader.setColorRampType( QgsColorRampShader.DISCRETE )
>      myColorRampShader.setColorRampItemList( theTBL )
>      theLayer.setDrawingStyle( QgsRasterLayer.SingleBandPseudoColor )
>      # - refresh map & legend
>      if hasattr(theLayer, "setCacheImage"):
>          theLayer.setCacheImage( None )
>      theLayer.triggerRepaint()
>      self.iface.legendInterface().refreshLayerSymbology( theLayer )
>      # - tell QGIS that it needs to ask user to save changes
>      self.iface.mapCanvas().setDirty( True )
> Cheers,
> Benoit
> -----Original Message-----
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org]*On Behalf Of *JP Glutting
> *Sent:* Saturday, 04 September 2010 17:47
> *To:* Qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Re: Raster layer display control from Plugin
> No takers? No hints? I have been looking all over the place, and I am
> stuck. If it is something absurdly simple, just point me in the right
> direction.
> Any ideas?
> Thanks,
> JP
> On Fri, Sep 3, 2010 at 7:50 AM, JP Glutting <jpglutting at gmail.com> wrote:
>> Although here (http://blog.qgis.org/node/94) it seems to indicate that
>> SingleBandPseudoColor is a constant:
>> mypLayer->setColorRampingType(QgsRasterLayer::BLUE_GREEN_RED);
>>   mypLayer->setDrawingStyle(QgsRasterLayer::SINGLE_BAND_PSEUDO_COLOR);
>>   std::deque myLayerSet;
>> which is what I was thinking in the first place, and here (
>> http://doc.qgis.org/stable/classQgsRasterLayer.html#36796f1a303dac9848ba3dce3e5527dc7b7c9814c053986846b579119d2e5be9 )
>> DrawingStyle is described as an enumerator, which seems coherent. I am not
>> sure how to do this from Python.
>> Cheers,
>> JP
>> On Fri, Sep 3, 2010 at 7:43 AM, JP Glutting <jpglutting at gmail.com> wrote:
>>> Actually, I am not even sure that first part is the way to do it. I tried
>>> this:
>>>  resultsLayer.setDrawingStyle(QtCore.QString('SingleBandPseudoColor'))
>>>          resultsLayer.setCacheImage(None)
>>>         resultsLayer.triggerRepaint()
>>> (passing the 'SingleBandPseudoColor' style as a string) and it makes the
>>> raster invisible. It still shows up black in the Layers Panel, but it
>>> doesn't show in the main window until you change the properties manually
>>> (and it is Grayscale when you do). It feels like I am pretty close, but I am
>>> not sure how to interpret this code from the QGIS documentation:
>>> myRasterLayer->setDrawingStyle<http://classQgsRasterLayer.html#3a923f732bedd87d0b920c5552215434>
>>> (QgsRasterLayer::SingleBandPseudoColor<http://classQgsRasterLayer.html#36796f1a303dac9848ba3dce3e5527dc7b7c9814c053986846b579119d2e5be9>
>>> (I never learned more than the basics of C++, and that was a long time
>>> ago). The source code seems to indicate that the format needs to be passed
>>> as a string (of course, when the layer is generated):
>>> 00204     QgsRasterLayer <http://classQgsRasterLayer.html>( int dummy,00205                     const QString & baseName = QString(),00206                     const QString & path = QString(),00207                     const QString & providerLib = QString(),00208                     const QStringList & layers = QStringList(),00209                     const QStringList & styles = QStringList(),00210                     const QString & format = QString(),
>>> 00211 const QString & crs = QString() );
>>> Thanks,
>>> JP
>>> On Fri, Sep 3, 2010 at 3:04 AM, JP Glutting <jpglutting at gmail.com>wrote:
>>>> Hello,
>>>> I am working on a plugin (I mentioned it on the list earlier, but it
>>>> isn't relevant to the question I have now). I have the results written to a
>>>> raster file, and I need to display it. I am using this code:
>>>>          resultsLayer =
>>>> qgis.core.QgsRasterLayer(self.query.results_file,
>>>> QtCore.QFileInfo(self.query.results_file).baseName())
>>>>  qgis.core.QgsMapLayerRegistry.instance().addMapLayer(resultsLayer)
>>>> which works fine for opening the file, but I would like to fine-tune the
>>>> display so the user doesn't have to reset the properties (in my test exaple
>>>> the values are 0 and 1 and the display is essentially all black). I would
>>>> like to either display the results in pseudocolor directly, or in grayscale
>>>> with the scale stretched to the min and max extent of the raster.
>>>> I tried the psuedocolor with this code:
>>>>  resultsLayer.setDrawingStyle(qgis.core.QgsRasterLayer.SingleBandPseudoColor)
>>>> which doesn't seem to do anything at all, and I am just guessing,
>>>> really.
>>>> I found a nice tutorial about how to calculate the min and max extent of
>>>> a raster and adjust the display here:
>>>> http://linfiniti.com/2010/08/a-simple-qgis-python-tutorial/
>>>> and I tried the following code:
>>>>         extentMin = 0.0
>>>>         extentMax = 0.0
>>>>         generateLookupTableFlag = False
>>>>         extentMin, extentMax =
>>>> resultsLayer.computeMinimumMaximumFromLastExtent(band)
>>>>         resultsLayer.setMinimumValue(band, extentMin,
>>>>         resultsLayer.setMaximumValue(band, extentMax,
>>>>         resultsLayer.setStandardDeviations(0.0)
>>>>         resultsLayer.setUserDefinedGrayMinimumMaximum( True )
>>>> but that fails with the following error:
>>>>  Traceback (most recent call last):
>>>>   File "/Users//.qgis/python/plugins/mcelite/MCELiteDialog.py", line
>>>> 361, in accept
>>>> TypeError: 'float' object is not iterable
>>>> and I don't understand what the float object is, exactly.
>>>> Any help or suggestions much appreciated.
>>>> Cheers,
>>>> JP
> Qgis-user mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100905/28255877/attachment-0001.html
