[Qgis-developer] Re: Error while compiling QGIS 1.5.0
Noli Sicad nsicad at gmail.com
Tue Sep 21 05:59:48 EDT 2010
Have you read this[1] instruction how build Qgis?
http://www.qgis.org/wiki/Installation_Guide
I think if you don't follow this instruction you are own your own.
Noli
On 9/21/10, mroddjob <david.thompson05 at gmail.com> wrote:
> A. Golubev wrote:
>> 02.mm.2010 12:51, Jürgen E. Fischer пишет:
>>> Hi Golubev,
>>> On Mon, 02. Aug 2010 at 11:58:12 +0400, A. Golubev wrote:
>>>> QGIS 1.4 compiles fine. Is there any solution?
>>>> MinGW 3.4.5, WinXP SP2, Qt 4.5.1
>>> Hm, http://lists.osgeo.org/pipermail/qgis-user/2010-April/008449.html
>>> suggest
>>> that this problem already existed in 1.4.   I don't know if anyone tried
>>> to
>>> build QGIS with MinGW.   The "official" builds are done with MSVC, which
>>> apparently doesn't have that problem.
>>> Jürgen
>> I dont have "qgis\src\core\gps" dir in my QGIS 1.4.0 src tree. Is there
>> any way to disable compiling of gps stuff or this is core functionality
>> now? If so, I will try MSVC. Thanks for help!
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Hi Golubev,
> Did you manage to get this to work?
> I am having the same problem, trying to build QGIS 1.5.0 in Qt Creator under
> windows xp. I get the same errors. Can anyone suggest a solution?
> Regards
> Oddjob
> http://osgeo-org.1803224.n2.nabble.com/Error-while-compiling-QGIS-1-5-0-tp5363180p5553920.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
