[Qgis-developer] gps toolbox (detect device on mac OSX 10.6.4)
John C. Tull jctull at gmail.com
Thu Sep 23 13:09:30 EDT 2010
That would be a good option. You should review the ticket and add a comment accordingly.
Cheers,
John
On Sep 23, 2010, at 7:37 AM, Massimo Di Stefano wrote:
> Way lost a so cool enanchment ?
> What a bout a small changes in  the gui ?
> the combobox is good to select the device .. but it has no  way to be populate manually, hence,
> why not add a "tool button" beside the combo-box, to open a file-dialogue
> se the user  can choose a device manually and when click on ok it will update the combo-box with the device address ?
> what do you think about ?
> thanks!
> Massimo.
> Il giorno 23/set/2010, alle ore 16.13, John C. Tull ha scritto:
>> Hi Massimo,
>> This is a known issue on OS X, but has received little attention to date. Other than manually setting up the path as you have done, I know of no other solution.
>> https://trac.osgeo.org/qgis/ticket/1170
>> Cheers,
>> John
>> On Sep 23, 2010, at 5:25 AM, Massimo Di Stefano wrote:
>>> Hi :-)
>>> i'm tring to use my bluethout gps device with Qgis,  but it is no recognized
>>> (there is no way in Qgis  to manually add the path to device) ..
>>> To fix i need to add manually "/dev/tty.GarminGPS10-Gps10" in : qgsgpsinformationwidgetbase.ui
>>> (i added my device in the .ui file using "add item" in the combo box widget)
>>> The weirs is .. after build qgis with the changes in " qgsgpsinformationwidgetbase.ui "
>>> i have no new entry in the combobox, it is empty
>>> but  just "select the first entry (position 1  in the combobox, where i added the item in the .ui file)
>>> it is empty ... (no device visible) but i'm able to connect to the device.
>>> Is inside qgis a place where i can "statically" set the path to my gps device ?
>>> Like a dialog to set manually the device address ?
>>> (instead or in addition to choose it from the combobox, beacouse autodetect device doesn't works as aspected)
>>> thanks for any hints!
>>> Best regards,
>>> Massimo_______________________________________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
