[Qgis-developer] QgisMapserver - need to restart Apache on every project file change ?
kimaidou kimaidou at gmail.com
Mon Apr 4 06:18:15 EDT 2011
Hi Andreas
Thanks for your prompt answer !
I will reload Apache configuration instead.
cheers
Kimaidou
2011/4/4 Andreas Neumann <a.neumann at carto.net>
> Hi,
> You need to reload, not restart Apache. A restart is not necessary. This is
> due to the caching mechanism QGIS server uses.
> This is suboptimal and will be improved in a future version, most likely in
> late spring. There will be a command to reload only one specific project
> without having to reload Apache.
> Andreas
> On Mon, 4 Apr 2011 11:20:57 +0200, kimaidou wrote:
>> Hi all, Marco,
>> I am testing Qgis mapserver on a demo server. I realized I needed to
>> restart Apache so that an server side project file has been modified
>> to see the changes in the WMS.
>> Is it "normal", or is it a misconfiguration on my side ?
>> NB : I am using ubuntu 10.10, and symbolic links to add any qgis
>> project + data as a new server.
>> Thanks in advance,
>> Kimaidou
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110404/fdb7b613/attachment.html
