[Qgis-developer] White stripes when panning map
Marco Bernasocchi marco at bernawebdesign.ch
Sat Apr 23 17:02:11 EDT 2011
confirmed on 15815 as well, it is not only on pan, as well when a dialog
is opened or closed over the canvas it Flickers.
removing the code from changeset 15771 eliminates the problem
ciao Marco
On 04/23/2011 10:21 PM, Ivan Mincik wrote:
> I see this behavior on three different machines with different graphic cards.
>> Do the white stripes disappear when panning is finished?
> Yes, it will disappear when panning is finished.
>> I don't have this effect on my machines here, but it could be related to the
>> resize crash fix (http://trac.osgeo.org/qgis/changeset/15771). Could you check
>> if the white stripes go away if you remove the few lines in qgsmapcanvas.cpp?
> Yes, it started when installed daily build containing that changeset.
> I can test removing lines later, if needed.
> Ivan
> Qgis-developer mailing list
Marco Bernasocchi
www.bernawebdesign.ch
skype: mbernasocchi
