[Qgis-developer] Use of Spatialite in a Python plugin for QGIS?
Stefan Keller sfkeller at gmail.com
Fri Apr 29 03:41:41 EDT 2011
Thanks for the hints!
I actually saw this note but I thought this was resolved since then.
So, are you saying that Spatialite can't be used out of Python plugins
for QGIS versions (1.6 / 1.7 trunk) in the meantime?
Yours, S.
2011/4/29 Noli Sicad <nsicad at gmail.com>:
> Hi Stefan,
> Better read this one (below) to fix some of the problems you mentioned.
> http://www.gaia-gis.it/spatialite-2.4.0-4/splite-python.html
> Please note on this caveat found in the document above.
> "Caveat
> The most recent QGIS versions (1.6 / 1.7 trunk) are actually using
> SpatiaLite v.2.4.0 so any Python plugin using the previous v.2.3.1 can
> easily cause conflicts due to version incompatilibiles. And this fully
> accounts for any issue noticed by QGIS users".
> Noli
> On 4/29/11, Stefan Keller <sfkeller at gmail.com> wrote:
>> Hello,
>> We are currently developing a Python Plugin for QGIS. We use
>> SpatiaLite to manage some data. What we want to do is, querying a
>> SpatiaLite database from a Python Plugin. We were able to get it to
>> work with SQLite, using the following code:
>> self.db = QSqlDatabase.addDatabase("QSQLITE")
>> self.db.setDatabaseName("path.to.db.file")
>> if self.db.open() == False:
>>     raise "Connection Error!"
>> query = QSqlQuery(self.db)
>> query.exec_("SELECT sqlite_version()")
>> if query.isActive():
>>     print str(query.value(0).toString()) #
>> else:
>>     raise str(query.lastError().databaseText ())
>> query.finish()
>> But when we try using a spatialite-function, like "SELECT
>> spatialite_version()", the query fails with "no such function:
>> spatialite_version". We tried to load the spatialite-Extension
>> manually, using "SELECT load_extension('libspatialite-2.dll');", but
>> that resulted in an exception "not authorized".
>> Our question is: What has to be done to use spatialite in a python-plugin?
>> There is pyspatialite(http://code.google.com/p/pyspatialite/), but we
>> would prefer using libraries already included in QGIS.
>> Thanks for your help.
>> Yours, Stefan and Tobias
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
