[Qgis-developer] Attribute data update of a shape file
maaza mekuria sailmcm at yahoo.com
Fri Apr 29 10:56:35 EDT 2011
Dear QGIS Gurus:
I have a written a plugin that updates an attribute of a shape file and it tells me it ran fine and yet, I am not able to see the changes in the attribute table once the program finishes. I am using QGIS 1.6 Copiapo on Windows). I am compiling using the 1.7 source, but I have tried using the trunk version and it does not seem to matter at all.
I can see the edit starting with all the extent selected and it finishes without an error. I also write a log file before and after the feature attribute change and the feature values change correctly.
What am i doing wrong?
The simplified code is posted below,
           QgsVectorDataProvider* vProvider = theVectorLayer->dataProvider();
           theVectorLayer->select(vProvider->attributeIndexes(),
           theVectorLayer->extent(), true, false);
           QgsFeature currentFeature;
           QgsGeometry* currentGeometry = 0;
                bool blnEdit = theVectorLayer->startEditing();
           QgsAttributeList attrList = vProvider->attributeIndexes();
      vProvider->select(attrList);
      blnFeat = vProvider->nextFeature(currentFeature);
      QgsAttributeMap atMap1;
            vProvider->createSpatialIndex();
      QString featureAttributesString;
                int ltsVal = 10;
                int ltsFldIdx = 1;
      QVariant fld0 ;
      while(blnFeat)
                       atMap1 = currentFeature.attributeMap();
         fld0 = atMap1.value(0);
         currentGeometry = currentFeature.geometry();
         if(!currentGeometry)
            continue;
         else
            currentFeature.changeAttribute(ltsFldIdx,QVariant(ltsVal));
      blnAttrAdded = theVectorLayer->commitChanges();
      theVectorLayer->endEditCommand();
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110429/0d7c5dbb/attachment.html
