[Qgis-developer] local installation of qgis trunk without GRASS plugin
Jürgen E. Fischer jef at norbit.de
Sat Apr 30 06:01:10 EDT 2011
On Sat, 30. Apr 2011 at 11:52:15 +0200, Otto Dassau wrote:
> Hi,
> when I compile qgis trunk and install it in a local folder
> (e.g. /software/qgis_trunk) all is fine except for the GRASS plugin. The
> libraries are build, but it is not selectable in the Plugin Manager.
> Does anybody know where the problem is?
It probably doesn't find the grass shared libraries.  Did you add
/opt/grass/lib to /etc/ld.so.conf or LD_LIBRARY_PATH?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
