[Qgis-developer] Provider native raster band stats
Tim Sutton lists at linfiniti.com
Wed Aug 3 05:00:56 EDT 2011
Hi Again
By the way is there a handy way to get the histogram from the aux.xml
too? I see it is stored there but havent figured out how to retrieve
it from cache again.
Regards
Tim
On Wed, Aug 3, 2011 at 10:16 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Tue, Aug 2, 2011 at 7:06 PM, Etienne <etiennesky at yahoo.com> wrote:
>> Tim, my impression is that it speeds things up, but I have a suggestion to make it faster.
> Cool!
>> From what I have seen in your code, the  QgsGdalProvider::bandStatistics function calls GDALComputeRasterStatistics (), which computes the statistics every time - it doesn't fetch pre-calculated data ( which is stored in gtiff metadata, or aux.xml file).
>> A better way would be to use the GDALGetRasterStatistics() which calls GDALComputeRasterStatistics() when needed (when bForce = TRUE)
>> double myerval =  GDALGetRasterStatistics ( myGdalBand, bApproxOK, TRUE, &pdfMin, &pdfMax, &pdfMean, &pdfStdDev);
> Ah - actually I thought GDALComputeRasterStatistics was using aux.xml
> cached stats already. I guess I never read the docs carefully enough.
> I applied your change and my ~8min to load raster from my original
> email took about a minute to load the first time (while gdal was
> creating an aux.xml) and subsequent use of the same raster resulted in
> it opening instantly! So thanks for your excellent advice. I have
> pushed an updated version to my repo that incorporates your changes
> should others like to try. I will try to write some unit tests this
> week and then merge my branch into QGIS master over the weekend.
>> I have tested it on a few rasters, it gets the same stats.
>> The downside is that GDALGetRasterStatistics() does not offer a progress callback, rendering the progressbar useless.
>> If it"s really needed, I could re-implement the function in  QgsGdalProvider (about 50 lines of code), or try to have GDALGetRasterStatistics support a progress callback.
> Yes this is quite noticeable the first time the raster is loaded and
> you sit wondering what is happening. I guess the more elegant would be
> to have the change carried out in gdal itself if that is acceptible,
> otherwise your patch as per your former suggestion would be greatly
> appreciated.
> Best regards
> Tim
>> regards, Etienne
>> ----- Original Message -----
>> From: Tim Sutton <lists at linfiniti.com>
>> To: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>> Cc: qgis-developer at lists.osgeo.org
>> Sent: Monday, July 11, 2011 7:04:08 PM
>> Subject: Re: [Qgis-developer] Provider native raster band stats
>> Hi
>> On Mon, Jul 11, 2011 at 5:29 PM, Marco Hugentobler
>> <marco.hugentobler at sourcepole.ch> wrote:
>>> Hi Tim
>>> I'm not a raster guru, but the changes look good to me.
>>> +1 for merging.
>> Thanks for your feedback Marco. I guess I'll write some unit tests
>> (wrong way around I know :-) ) and then merge it if they all pass and
>> there are no other objections. :-)
>> Regards
>> Tim
>>> Regards,
>>> Marco
>>> Am Donnerstag, 7. Juli 2011, 00.47:25 schrieb Tim Sutton:
>>>> Hi
>>>> During the Lisbon hackfest (between all those meetings!) I worked on
>>>> updating the raster providers to be able to generate stats themselves.
>>>> The raster provider base class has a default (and historically
>>>> inefficient as we all know) implementation for collecting stats by
>>>> walking over every cell in the raster twice. This method remains, but
>>>> the providers can now supply stats themselves (heopfully using more
>>>> efficient mechanisms). I have implemented gdal native stats already.
>>>> Over the last few weeks I did some further testing and cleanups to
>>>> this work. From my testing some of my worst case files opened in
>>>> ~1minute rather than ~8+ minutes. It would be great if interested
>>>> parties could test (details below) before I put it into master.
>>>> git remote add timlinux git://github.com/timlinux/Quantum-GIS.git
>>>> git fetch timlinux
>>>> git branch --track timlinux raster-stats
>>>> git checkout raster-stats
>>>> I look forward to your feedback.
>>>> Regards
>>> Dr. Marco Hugentobler
>>> Sourcepole -  Linux & Open Source Solutions
>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>> Technical Advisor QGIS Project Steering Committee
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Skype: timlinux
Skype: timlinux
