[Qgis-developer] analytical workflow
Johan Van de Wauw johan.vandewauw at gmail.com
Wed Aug 24 03:26:15 EDT 2011
Sextante has a nice modeler tool - it may be a good example how it could work:
http://www.gvsig.com/files/images/screenshots/gvSIG_Sextante_02.png
AFAIK it also handles saga (although most modules were reimplemented
in java) and even grass modules.
In fact Sextante is already a processing toolbox - it is written in
java  so I'm not sure if it could be integrated in qgis, but if a new
framework is built in c++/python, it is nevertheless very interesting
to see which design decision they took.
Johan
On Tue, Aug 23, 2011 at 9:45 PM, Camilo Polymeris <cpolymeris at gmail.com> wrote:
>> I agree with martin - such a Modeler could be a great improvement but
>> I assumed it would be somethink like the WxGUI_Modeler ..
> Yes, I also imagine something similar.
> But, I prefer more ordered layouts, where you have all outputs in a
> column on the left side, and all inputs in a column on the right side.
> In between all connections displayed as lines of different color
> depending on parameter type and such.
> A bit like qjackctl's patchbay:
> http://ubuntu.allmyapps.com/data/q/j/qjackctl-jack-control/UBUNTU-9.04/qjackctlPatchbayForm1.png
> It looks tidier and would also be a bit easier to implement than
> free-floating boxes.
> On the logic side:
> For input and output the most flexible would be to use python scripts.
> Of course, it is harder than e.g. XML, and there would be limits to
> what python code it would understand on input. But still, I think it
> is the best option.
> The user would then have the option of saving these "workflow presets"
> and using them like any regular module.
> Camilo
> Qgis-developer mailing list
