[Qgis-developer] QgsExpression: replacement for QgsSearchString
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Aug 29 02:39:38 EDT 2011
Hi all
Seems it depends also on the bison version.
I'm getting some errors with bison 2.3. With bison 2.4.1, it works nicely.
 cd /opt/qgisms/src/Quantum-GIS/build/src/core && /usr/bin/bison -
o/opt/qgisms/src/Quantum-GIS/build/src/core/qgsexpressionparser.cpp -d -v -t
/opt/qgisms/src/Quantum-GIS/src/core/qgsexpressionparser.yy
/opt/qgisms/src/Quantum-GIS/src/core/qgsexpressionparser.yy:54.14-19: syntax
error, unexpected string, expecting =
(bison 2.3 understands only deprecated syntax %name-prefix = "exp_" )
/opt/qgisms/src/Quantum-GIS/src/core/qgsexpressionparser.yy:120.28-33: syntax
error, unexpected type, expecting string or identifier
Seems 2.3 does not support the <> notation. Not sure what to do here...
Regards,
Marco
Am Sonntag, 28. August 2011, 19.28:08 schrieb Tim Sutton:
> Hi
> I'm getting  a lot of win build errors relating to qgsexpression:
> http://pastie.org/2444030
> It could just be some stale binaries left behind that msvc is hanging
> on to - still investigating...
> Regards
> Tim
> On Sun, Aug 21, 2011 at 1:56 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> > Looking good Martin.  No objections from me.  The old QgsSearchString was
> > a bit string in the way it handled a few things so I'm glad it's been
> > simplified in your chances.
> > I'm just merging with my expression labeling branch, which used
> > QgsSearchString at the moment. I will report if I find any bugs.
> > - Nathan
> > On Sat, Aug 20, 2011 at 6:51 AM, Martin Dobias <wonder.sk at gmail.com>
wrote:
> >> Hi everyone
> >> recently I have been trying to fix some flaws in search string
> >> implementation and it turned out that rather than fixing them
> >> one-by-one it will be easier to rewrite that code completely. Search
> >> string and associated searching in attribute table was one of my first
> >> contributions to QGIS and my first attempt to write a parser and an
> >> evaluator. QgsExpression is my second attempt :-)
> >> The main reason for the redesign was to bring the evaluation closer to
> >> SQL semantics and to clean the code which started to be hard to
> >> maintain.
> >> QgsExpression is meant to be a replacement for QgsSearchString class.
> >> Most of the changes are under the hood:
> >> - fixed and simplifed the parser grammar and tree creation
> >> - simplified lexer
> >> - only one evaluation routine (instead of separate
> >> getValue/checkAgainst) - correct handling of NULL values and
> >> three-value logic from SQL (true, false, unknown)
> >> - fixed error reporting
> >> - easily extensible list of functions, saner evaluation of expressions
> >> - using QVariant for return values instead of a special type
> >> - slightly faster evaluation
> >> - a more suitable class name
> >> - tests included (!!!) :-)
> >> Only few changes are visible for users:
> >> - spaces were removed from "to int", "to real" and "to string"
> >> functions because function names must not contain spaces
> >> - null values are handled correctly by the functions and operators
> >> - errors are reported when conversions between types fail
> >> Btw. type conversions (currently supporting null, int, double, string)
> >> are implemented in many different ways in databases. I have done some
> >> tests on sqlite3, postgresql and mysql and many times there was no
> >> consensus what the outcome of an evaluation should be:
> >> - 7 > '6x' :: mysql=1, sqlite=0, postgresql=error
> >> - 7 > '6' :: mysql=1, sqlite=0 (!), postgresql=1
> >> - '6x' :: mysql=6 (+warning), sqlite=6, postgresql=error
> >> - '3'+'5' :: mysql=8, sqlite=8, postgresql=error
> >> - 3/5 :: mysql=0.6, sqlite=0, postgresql=0
> >> - length(123) :: mysql=3, sqlite=3, postgresql=error
> >> - 0 or 1 :: mysql=1, sqlite=1, postgresql=error
> >> - 0 or 'x' :: mysql=0 (+warning), sqlite=0, postgresql=error
> >> PostgreSQL is very strict about type conversions, Sqlite is not strict
> >> at all and MySQL is somewhere in the middle. I have ended up with
> >> these conversion rules:
> >> - implicit conversions to desired types
> >> - string->number conversions with invalid input return error
> >> - arithmetic operators convert to numeric
> >> - comparison with numeric type => numeric comparison
> >> The code is here:
> >> https://github.com/wonder-sk/Quantum-GIS/tree/expr
> >> If there are no objections I will apply the changes to master in few
> >> days. Given that I have been simultaneously writing unit tests I am
> >> quite confident that there are not too many bugs (unit tests really
> >> help!). In that branch I have replaced all the occurrences of search
> >> string with expressions. So playing with search in attribute table or
> >> doing calculation in field calculator will use the new engine.
> >> Martin
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
