[Qgis-developer] Create vector layer directly in PostGIS
uk52rob uk52rob at yahoo.co.uk
Wed Aug 31 06:52:00 EDT 2011
Thanks Richard, makes more sense now. Just a shame it is not implemented
directly in QGIS, rather than being a plug-in.
Cheers,
Rob
-----Original Message-----
From: Richard Duivenvoorde [mailto:rdmailings at duif.net]
Sent: 31 August 2011 11:32
To: uk52rob
Cc: 'Giovanni Manghi'; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Create vector layer directly in PostGIS
On 08/31/2011 12:13 PM, uk52rob wrote:
> Giovanni,
> Thanks, but this only seems to be able to load in shapefiles.
> What I would like is to remove the need to store a shapefile in the first
> instance.
> Eg. Press the 'New Shapefile Layer' toolbar button, fill in the
attributes,
> then select a PostGIS DB to store to, not a shapefile.
No need to make a shapefile.
Start postgis manager, make a connection to your database en use button
'create table'. There you have the same dialog as you have with making a
new shapefile: give a name, type of geometry and add attributes.
Regards,
Richard
