[Qgis-developer] building qgis on centos
ludovic mercier ludovic.mercier at gmail.com
Tue Dec 6 10:42:54 EST 2011
Hi, Santhosh,
you must installed qtwebkit-dev, the development package for build qgis.
Not only qtwebkit.
regards
Ludovic
Le 06/12/2011 16:26, santhosh shirrali a écrit :
> hello
> iam trying to build qgis on centos 6 after installing all the dependency packages iam getting the following error in
> ccmake ..
>   CMake Error at CMakeLists.txt:192 (MESSAGE):
>     Some Qt4 modules haven't been found!
> Qt QTWEBKIT library not found.
> and after that i installed Qt webkit from the rpm source but iam getting the same mistake can any body give a solution
> how to solve this problem
> Regards
> Santhosh
> Qgis-developer mailing list
