[Qgis-developer] pre install run has no python plugins
Sandro Santilli strk at keybit.net
Tue Dec 6 12:47:57 EST 2011
On Tue, Dec 06, 2011 at 07:28:34PM +0200, Alexander Bruy wrote:
> Hi Marco,
> AFAIK when running from build directory QGIS don't have Python plugins
> and this is know and correct behavior. See Martin's email about this [0]
I wouldn't call it "correct behavior".
Why would you want a "pre-install" runtime to use "post-install" stuff ?
On Mon, Jul 25, 2011 at 8:08 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> There are few things I am aware of that
> do not work right now when run from build directory (though they work
> when installed):
> - python plugins included in source tree (fTools, installer, gdal
> tools, osm) are not visible. Their source files would need to be
> copied to some directory so that they see the generated files -
> otherwise they would fail to start
I think such copy or symlinking or whatever is needed should be
implemented somehow in a way to allow _full_ off-system runs.
Don't you agree ?
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
