[Qgis-developer] Crash when adding an image to the print composer
Andreas Neumann a.neumann at carto.net
Wed Dec 7 11:20:48 EST 2011
 Werner - I just tested with OSGeo4W 1.7.2.1 on Windows and the problem
 still exists if you set project properties to "relative paths".
 Here is the commit with the fix that needs to be backported:
 https://github.com/qgis/Quantum-GIS/commit/917f748d33d4a41f700e744c9b54792e4355257a
 Thanks,
 Andreas
 On Wed, 7 Dec 2011 17:09:00 +0100, Werner Macho wrote:
> Hi
> I just tried to add a Image to the Print composer in upcoming 1.7.3
> without any problem .. So I'd say probably this is not a problem in
> 1.7.x
> But I could also do something "wrong".. Just adding a jpg as image to
> print composer works in my case
> regards
> Werner
> On Wed, Dec 7, 2011 at 4:42 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi,
>> Yes - I ran into the same problem.
>> Question: is the bug also in 1.7x? If yes, the fix would have to be
>> backported? I agree it is a major bug, if it also exists in 1.7x
>> Andreas
>> On Wed, 07 Dec 2011 15:22:14 +0100, Marco Hugentobler wrote:
>>> Hi Paolo
>>> Is that on current master from today? I remember having fixed that
>>> last friday.
>>> Regards,
>>> Marco
>>> On 07.12.2011 15:18, Paolo Cavallini wrote:
>>>> Hi all.
>>>> I got a sytematic crash when adding an image to print layout:
>>>> Fatal: ASSERT: "!isEmpty()" in file
>>>> /usr/include/qt4/QtCore/qlist.h, line
>>>> 274
>>>> I kind of remember this was raised recently.
>>>> I think this is a crucial issue, to be fixed ASAP, and is a recent
>>>> regression.
>>>> All the best.
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
 Andreas Neumann
 Switzerland
