[Qgis-developer] License
strk strk at keybit.net
Tue Feb 1 16:07:42 EST 2011
On Tue, Feb 01, 2011 at 08:06:26PM +0100, Marco Hugentobler wrote:
> Hi Sven
> The qgis libraries (libqgis_core, libqgis_gui, libqgis_analysis) are GPL ( not
> LGPL! )
> > As i consider to integrate the Libraries in our product, i wonder if I then
> > have to give away the source code with it.
> You are not obliged to publish it (e.g. using it internally inside a company
> is not considered as publishing). In that case you don't have to give away the
> source (see http://www.gnu.org/licenses/gpl-
> faq.html#GPLRequireSourcePostedPublic)
> But if you publish it (e.g. give it to another company, sell binaries, etc.),
> you need to provide the source.
May I add: "... to the same recipients you deliver the binary".
You basically need to give your _customer_ a better service:
access to the sources and the license to modify it and redistribute it.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
