[Qgis-developer] A roadmap to QGIS 2.0
Martin Dobias
wonder.sk at gmail.com
Fri Feb 4 07:32:38 EST 2011
Hi Juergen
On Fri, Feb 4, 2011 at 11:27 AM, Jürgen E. <jef at norbit.de> wrote:
> Did I miss Martins comments on that? I didn't find any.
Sorry for not joining the discussion, first I was too busy, then I've
been away, so after 14 days I thought it's too late to join the
discussion :-)
Anyway I'm going to share my thoughts now.
I agree with Tim's goals for the 2.0 release. I also agree with the
point that we should do few releases (e.g. 1.9.x) before 2.0 that
would incrementally throw out old stuff and bring a lot of polish, so
that 2.0 will be merely a renamed 1.9.x version - in order to have a
solid release, not a feature-packed unstable release. (Probably many
people will give 2.0 a try and if it's buggy they'll wait again for
3.0). At the same time I would be a bit more modest regarding the
timeline, but as Tim noted, it looks like everyone has a different
opinion on that and his plan is quite reasonable.
One of the many things that I would like to see in 2.0 is a reworked
geometry class. I hope everyone who knows the inner working of
QgsGeometry will agree with me :-) I think boost.geometry library
(former GGL) is a strong candidate for the backend, since it starts to
mature and has several advantages over GEOS:
- allows to use our own geometry classes - no need to copy geometries
back and forth
- it's pure header library - so it's only build dependency, not
runtime dependency
It could miss some functionality that is available in geos, though - I
haven't done an extensive comparison yet.
One of the important things is how/when to merge the threading branch.
I know that just few people tried it, so I didn't get much feedback
apart from Marco's and Pirmin's comments. As of now, I am aware of
just one important blocker that prevents me to merge the branch (there
will be probably few bugs, but I don't think of them as critical).
The blocker is the issue of threading vs python. Python in general is
not a great friend with threading - it has an infamous Global
Interpreter Lock (GIL) which ensures that only one thread in
application can run Python code. To enable threaded applications, GIL
is unlocked periodically (when running python code) and locked again
to give other threads a chance to run The problem in QGIS shows up if
any part of the rendering stack is in Python. That could be a custom
symbol layer instance, custom renderer or a custom "plugin" layer.
Rendering freezes at that point, because Python code is waiting for
GIL, but it doesn't receive it since no Python code is running either
(in main thread) that could unlock the GIL. The question is how to
handle this situation. I had few ideas how to solve this:
- run periodically some python code in main thread, so GIL could be
acquired by rendering thread. This is lame: if called often, it eats a
lot of cpu, if called rarely the code in rendering thread progresses
slowly.
- unlock GIL manually when rendering starts and lock it again when
rendering finished. Until now I have failed to produce a result which
wouldn't crash/deadlock when tried running python code in main thread
while rendering thread is running python code. (As someone noted on
one mailing list, python documentation for this topic is clear as
mud).
- identify which parts of the rendering stack are in python and
explicitly run rendering of these layers in main branch. This would
actually avoid the whole problem and might work fine. I haven't
investigated this option yet, I'm mainly interested in an simple way
how to find out if a class is implemented in python.
I would appreciate any comments for that.
Among the smaller issues, there should be more aggressive locking to
prevent data corruption when rendering and modifying the data at the
same time (e.g. vector edit buffer, raster/vector layer properties). I
also had to remove connection pooling for postgis layers from one
server, since it's not possible to read data for more than one layer
at once from one connection. But these things can be fixed as the time
goes.
> Did anyone try merges yet?
I haven't tried to merge the code yet.
I would recommend to merge Radim's raster providers branch prior to
the threading branch, since it's much simpler. However then we will
have to make sure that rasters work correctly with the threading.
> I've was going to try - but I all I managed so far is to get git (and that took
> quite some amount of persuasiveness to get there - git rookie here) to checkout
> trunk, rasterproviders, threading and table branch into one repository.
> I'd like to work more on the forms stuff and I think the table join branch
> could be a prerequisite for that.
> Anything I can do to help with the merges?
It will be useful to merge the table join branch to threading branch
first, and then update it with the zillion of commits that happened in
trunk in meanwhile. With that help, I think threading branch could be
merged to trunk much sooner. I would really appreciate that!
Regards
Martin
