[Qgis-developer] qgis web
Andreas Neumann a.neumann at carto.net
Sun Feb 13 07:20:26 EST 2011
yes - I also think that what Mohammed is trying to do is already
supported out of the box from QGIS server. It can ready a QGIS project
file and use it as the WMS configuration, it can read shp-files and
convert it into raster files (png/jpg/gif) using the standardized WMS
protocol.
What else would you want that QGIS server doesn't already provide?
Andreas
On 2/13/11 1:03 PM, Richard Duivenvoorde wrote:
> Mohammed Rashad wrote:
>> I am trying to build an online shapefile viewer using qgis as a
>> backend. for that i need to render qgis output to a image(.png) file
>> I cannot use QgsMapCanvas class because it requires QApplication I
>> cannot use any class from qgis_gui
>> but qgis_core can be used.
>>  QgsVectorLayer * mypLayer = new QgsVectorLayer(myLayerPath,
>> myLayerBaseName, myProviderName);
>>   QgsSingleSymbolRenderer *mypRenderer = new
>> QgsSingleSymbolRenderer(mypLayer->geometryType());
>>   QList<QgsMapCanvasLayer> myLayerSet;
>>   mypLayer->setRenderer(mypRenderer);
>>   if (mypLayer->isValid())
>>     cout << "Layer is valid";
>>   else
>>     cout << "Layer is NOT valid";
>>     return;
>> the following code works for me in Wt. It prints layer is valid or
>> invalid according to the parameters to QgsVectorLayer()
>> can I set mypLayer->setRenderer of the above code to an image file so
>> that rendering occurs on a image file of my choice?
>> It hope now the problem is clear.Now can you help me?
> Nope, sorry I'm not that deep into cpp coding.
> But from what you write it seems that you actually want a WMS. So why
> not have a look at the mapserver_qgis WMS? This can generate an image
> from a given qgis-project file for you. It's also probably interesting
> to look into that code
> https://svn.osgeo.org/qgis/trunk/qgis/src/mapserver/
> Actually I'm also wondering if it would be easy to build a mini python
> application which:
> 1) reads a qgs project file (see mapserver export plugin for that)
> 2) then paints the map on a given hidden mapcanvas of a given size and
> bbox (this is the hard part I think?)
> 3) writes this to an image
> Maybe somebody else?
> Richard
> Qgis-developer mailing list
