[Qgis-developer] Bringing diagrams into labeling-ng
Tim Sutton
lists at linfiniti.com
Tue Feb 15 16:01:35 EST 2011
Hi
As with Juergen, I don't have much insight into the code, but the
principle sounds great to me and it would be nice to be able to
interactively place the diagrams as you have done with labels. How
would the diagram's placement be persisted? In the same way as labels
using a specified columns? Some users have requested that label
placement could work like E$RI where the labels can be turned into
graphics and placement is stored in the project file (or whatever the
ESRI equivalent of that is) - so that you don't need to have write
access to the dataset.
Anyway +1 from me, I look forward to your improvements!
Regards
Tim
On Tue, Feb 15, 2011 at 2:16 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Marco,
> On Tue, 15. Feb 2011 at 10:16:06 +0100, Marco Hugentobler wrote:
>> Therefore I'm proposing a change to QgsPalLabeling. To make the system more
>> extensible, it would be good to have QgsPalGeometry as an abstract base class
>> and derive QgsPalLabelGeometry from it (and diagram specific classes later
>> too). Each QgsPalGeometry would implement size calculation and drawing in its
>> specific way.
>> Any objections or better ideas?
> Not much insight in that here, but sounds nice to me. +1
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
