[Qgis-developer] Re: [saga-gis-developer] saga - qgis interface
Paolo Cavallini
cavallini at faunalia.it
Thu Feb 17 01:27:21 EST 2011
Il giorno gio, 17/02/2011 alle 01.27 +0100, Volker Wichmann ha scritto:
> the Gdal-Tools seem to be more or less hard-plugged: every tool has its
> own description (.py file). Is your idea to generate these files (I'm
> not familiar with pyQT, but I would expect that generating these files
> would be a separate step, e.g. by running a script and committing the
> files to the QGIS source), which would be necessary for every API/module
That's right: on the other hand, GRASS modules are autogenerated from
the xml description.
I think this second approach is much better if modules are >>10, and if
the interface of all modules is more or less constant.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
