[Qgis-developer] Plugin Development C++ Windows - Any response?
G. Allegri giohappy at gmail.com
Fri Feb 18 06:02:36 EST 2011
Maaza, I think your approach doesn't help to give you a hand.
The community cannot supply you the *time* you should invest in trying and,
maybe, learning the necessary basics to do what you need. You shoud try and
try and the, eventually, ask about things that go wrong.
QGis plugins are C++, with some macros defined by Qt. Nothing more, nothing
less (am I wrong?). If you're able to compile C++ code in Visual Studio, you
don't need to rely on Cmakelist. It can help, because it makes a lot of work
for you, and you can be inspired by other plugins. But you also can build
and link the usual way.
Have you read the "QGIS Coding and Compilation Guide" [1]?
giovanni
[1]
http://download.osgeo.org/qgis/doc/manual/qgis-1.6.0_coding-compilation_guide_en.pdf
2011/2/18 maaza mekuria <sailmcm at yahoo.com>
> Can it be possible to create a minimalist plugin using c++ in Windows
> Visual C++ Express without using all the bells and whistles that are in the
> other plugins such as CMakelists?
> Your help may make a difference between using Python and C++. I was able to
> copy a Python plugin and easily adopt it to my own version of a plugin. I
> was able to add and remove GUI items by just editing the UI file. I want to
> do something similar using C++. Is it impossible for a new comer? Do I need
> a Computer Science degree to? But it should not be as they say "Rocket
> science" to write a little function.
> I promise if I get it to work, I will share it with those who are suffering
> the famine for information. I am not sure why there is lack of documentation
> on such a simple matter or may be it is not simple or it is esoteric because
> it is highly dependent on many secret doors and passageways.
> I confess my stubbornness to use C++ is due to the type of work being a bit
> intensive and I also have already a C++ code for it and I just need a nicer
> interface and data store that is free as in "Free Chai" inside QGIS.
> Anybody there listening to the call from QGIS (Quiet or Slow GIS) desert?
> Maaza
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110218/96d64587/attachment-0001.html
