[Qgis-developer] Issue saving shapefiles with REAL15 values
Anita Graser
anitagraser at gmx.at
Tue Feb 22 10:51:07 EST 2011
Am 22.02.2011, 14:49 Uhr, schrieb Barry Rowlingson
<b.rowlingson at lancaster.ac.uk>:
> On Tue, Feb 22, 2011 at 12:37 PM, Anita Graser <anitagraser at gmx.at>
> wrote:
>>> You can extract just one record, and share that one.
>> How? If I use QGIS, the values will be broken.
> ogr2ogr on the command line?
ogr2ogr results in the same broken values. Looks like it's a GDAL problem.
> what does ogrinfo say about it?
INFO: Open of `nw.shp'
using driver `ESRI Shapefile' successful.
1: autaut________nw_wien (Line String)
> Can you load the DBF in a spreadsheet?
Yes, Openoffice loads them. The header says ID,N,15,0. QGIS displays
REAL15 in fields tab of layer properties.
> How do you know what the values are supposed to be?
The data comes with documentation.
Thanks for your help,
Anita
