[gdal-dev] Re: [Qgis-developer] Issue saving shapefiles with REAL15 values
Anita Graser anitagraser at gmx.at
Tue Feb 22 10:51:10 EST 2011
I used the following ogr2ogr command:
ogr2ogr -sql "select * from nw where NAME = 'Am Johannesberg'" new.shp
nw.shp
The resulting shp contains correct geometries, but the values in ID,N,15,0
fields are broken.
I guess that shows that it's a GDAL/OGR problem.
Thanks, best wishes,
Anita
Am 22.02.2011, 16:33 Uhr, schrieb Chaitanya kumar CH
<chaitanya.ch at gmail.com>:
> Anita,
> First, let us isolate the source of this error. QGIS or GDAL/OGR.
> Use ogr2ogr to clip the part you did with QGIS. See the extents of the
> clipped shapefile using ogrinfo and use it with the ogr2ogr utility.
> http://www.gdal.org/ogr2ogr.html
