Re[6]: [Qgis-developer] When a code freeze?
Sergey Yakushev yakushevs at list.ru
Fri Feb 25 22:55:00 EST 2011
Fri, 25 Feb 2011 22:43:30 +0200 письмо от Tim Sutton <lists at linfiniti.com>:
> Hi
> On Fri, Feb 25, 2011 at 10:10 PM, Sergey Yakushev <yakushevs at list.ru> wrote:
> > Fri, 25 Feb 2011 18:33:38 +0200 письмо от Tim Sutton <lists at linfiniti.com>:
> >> > Can you make it
> >> > work in some default way so that configuration of the plugin is not
> >> > mandatory?
> > It isn't good idea, I think. User looks at the the settings window, and
> understands how the plugin works.
> Ok maybe at least just popup the settings dialog then.
> Also I think the following label changes should be made in that dialog:
> Direct direction -> Value for forward direction
> Reverse direction -> Value for reverse direction
> Both direction -> Value for two-way direction
Thanks! My English is very bad. This is a very big help.
> Maybe it would also be good to make those combos where you pick the
> value rather than text box where the user needs to know the values a
> priori.
Yes, I agree. But advanced export tool and progress bar it is a priority.
> Regards
> Tim
> >> > Thanks for this awesome tool!
> >> Oh one other suggestion is just to have an hourglass or progress bar
> >> so the user understands that it is busy calculating!
> > I thought about it. Many people tell me about it. I will do it to release
> qgis.
> > It is "fix GUI before code freeze".
> >> Thanks again!
> > С уважением Якушев Сергей yakushevs at list.ru
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
