[Qgis-developer] Raster providers
Tim Sutton lists at linfiniti.com
Mon Feb 28 04:59:21 EST 2011
Hi
On Mon, Feb 28, 2011 at 10:01 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Sun, Feb 27, 2011 at 9:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> Do you have anything else left on your todo list before you can merge to trunk?
> It looks like this:
> qgsrasterprojector.* qgsrasterdataprovider.* raster/qgsrasterlayer.* : 60 TODOs
> qgsgdalprovider.*: 11 TODOs
> qgsgrassrasterprovider.*: 8 TODOs
> qgswmsprovider.*: 53 TODOs
> But all those TODOs are not really problem, IIRC, before the merge I have to add
> only fall back to precise reprojection if approximation fails (easy)
> and code cleanup.
> The problem with data reloading on update (G. Manghi reported) I would
> like to solve in trunk
> because it may need QgsLayer and renderer modifications.
> Then, there are some places, usually constants which have
> to be checked better (e.g. max error, in reprojection, minimum source
> resolution etc.)
> That can still be done in trunk, I think.
That being the case, I would suggest we poll Marco and other devs to
see if it can move into trunk so that it can be more broadly tested
before the release - I don't think it will be good to merge it at the
last minute before the release for this reason.
> BTW: The approximate reprojection could may be used also for vectors?
Hmm interesting. Is there a summary of the logic you have used to do
this somewhere?
Regards
Tim
> Radim
>> +1 from me to merge when you are ready
>> I would like to make some cleanups to the raster properties dialog
>> after you are done...hopefully I can do the ui clean upsin time for
>> 1.7....
>> Regards
>> Tim
>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>>  * QGIS programming and support services
>>  * Mapserver and PostGIS based hosting plans
>>  * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
Skype: timlinux
