[Qgis-developer] WktRaster 0.3
Noli Sicad nsicad at gmail.com
Tue Jan 4 22:55:15 EST 2011
Hi Mauricio,
Thanks for this plugin,
Suggestions
1. I think it would be good to put this plugin into "Database" Menu.
So we can easily find it with the rest of the database plugins. This
also prevent the over crowding of the "Plugins" menu.
2. Then probably "PostGIS Raster" instead of "Add Postgis a raster
layer" since you already the same sub menu (i.e. "Add Postgis a raster
layer")
3. Kindly place a changelog file so we know what is new in this plugin.
Thanks.
Noli
On 1/5/11, Maurício de Paulo <mauricio.dev at gmail.com> wrote:
> Hi devs,
> I've updated the wktraster plugin to solve a few issues and to implement the
> data loading gui.
> Now the plugin have an interface to load data to the database.
> I know jorge is going to ask for a few more options on the ui but I thought
> that it should be as clean as possible at first. Loading data is still a
> non-trivial task so I forced a single use case.
> I couldn't test the gdal version tester as I found my windows gdal version
> is now 1.7.
> At least I could test the data loading and visualization of the utm.tif file
> on windows 7 (thanks OSGEO4W).
> I hope you enjoy.
> Best regards,
> Mauricio de Paulo
> Engenheiro Cartografo
> MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
