[Qgis-developer] multi-view
Massimo Di Stefano massimodisasha at yahoo.it
Thu Jan 13 09:31:54 EST 2011
Hi Ludovic,
nevermind .. your efforts are not lost
beacouse the patch is old, it needs to be revisited
and your work with multispectral analisys results
can be fused with the addtab patch.
just having it fixed to be able to apply it on the actual trunk .. should be a good first step
it is also nice to have you intersted on multiview too,
maybe this time we will finally have it implemented in qgis
i like and use the multiview capability (like in grass).
note, i was just a guinea pig (tester) for it :-)
all the hard cpp work was made by LinxID
All my thanks to Him!
thanks!
Massimo.
Il giorno 13/gen/2011, alle ore 08.55, qgis-developer-request at lists.osgeo.org ha scritto:
> Hi Massimo,
> i don't know your patch (1622).
> it's very interresting. I think : i have "worked for nothing" :(
> I will try to install it.
> regards
> Ludovic
> Le 13.01.2011 14:16, Massimo Di Stefano a écrit :
>> Hi All,
>> multiview is nice and remember me the addtab capabilities
>> (that's an other way to have multiview,
>> the tab are detachable and mouse over on the relative tab show a
>> canvas preview)
>> so, i hope the multiview work will not forget as :
>> http://trac.osgeo.org/qgis/ticket/1622
>> lynxID and me worked hard to develop and test it,
>> AddTabb patch was needed to start to develop the planet plug-in.
>> The patch was never applied due to main api change ?
>> Il giorno 13/gen/2011, alle ore 05.35,
>> <mailto:qgis-developer-request at lists.osgeo.org> ha scritto:
>>> Hi Ludovic
>>> Looks nice. Yes, multi view is definitely of interest.
>>>> If yes, i am interesting to know how to integrate this to official qgis
>>>> code.
>>> The best thing is to create a patch that can be applied to the
>>> current trunk
>>> version (1.4 is a bit old now). Create a ticket in trac
>>> (http://trac.osgeo.org/qgis) , attach the patch and add a bit of textual
>>> description. It will then be review by the dev team.
>>> Regards,
>>> Marco
>>> Am Donnerstag, 13. Januar 2011, um 09.51:29 schrieb ludovic mercier:
>>>> Hi all,
>>>> thanks for all developer for this big and great work on qgis.
>>>> I work for an astrophysics and planetology laboratory and i have create
>>>> a qgis fork with 1.4.0 version.
>>>> Many researcher work with envi software to analyse their image and use
>>>> multi-view to work.
>>>> So i create a fork to add multi-view and hyperspectral analyse. See the
>>>> link
>>>> http://www.coriolys.org/post/2011/01/13/VahineView-fork-of-Qgis-software
>>>> for a screen shot.
>>>> My question is this feature (multi-view) is interesting for qgis team ?
>>>> code.
>>>> In this time i have still some little bugs with interaction between
>>>> active view and zoom-view at the right bottom.
>>>> For the time being i work only in the hyperspectral analysis tool.
>>>> regards
>>>> ludovic
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110113/fe4695a6/attachment.html
