[Qgis-developer] Python scrpt to join attributes from DBF - ftools is very slow
Alex Mandel tech_dev at wildintellect.com
Sun Jan 16 02:15:06 EST 2011
Yes, one option is to do this in a database. I do things like this in
spatialite all the time. Import your shp and your table then do a join
either temporarily as a view or make a new table.
SELECT * FROM shp JOIN table on shp.id = table.id
Enjoy,
Alex
On 01/15/2011 08:22 PM, Noli Sicad wrote:
> Yes, I tried MMQGIS. It did not work. It read the column names but
> not the data.
> Ftools is more robust than mmqgis, I think. It is just slow.
> I understand Ftools is in the process of being ported to C++ plugins.
> Noli
> On 1/16/11, Maurício de Paulo <mauricio.dev at gmail.com> wrote:
>> I think I've seen a plugin called mm something that had a join tool in the
>> repository.
>> On Sun, Jan 16, 2011 at 12:36 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi,
>>> I am trying to join attributes from DBF file to shapefile and I find
>>> flools very slow to do this job.
>>> Here is the facts
>>> 1. DBF file is 44.8 Mb to be joined to shapefile
>>> 2. flools is working but only creating 2 Mb per 30 minutes on dbf file.
>>> 3. Qgis freezed by flools is still working.
>>> At this rate, it will take me 22 hrs to get the final result.
>>> Any python script or any script, solution to speed this job?
>>> Do you think doing this job using spatialite will speed up completion
>>> of this job?
>>> Thanks.
>>> Noli
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Mauricio de Paulo
>> Engenheiro Cartografo
>> MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
