FW: [Qgis-developer] RE : Debugging QGIS Bugs
Tim Sutton tim at linfiniti.com
Tue Jan 18 07:02:13 EST 2011
Hi
Radio button one is probably more appropriate in this case.
Regards
Tim
On Tue, Jan 18, 2011 at 1:17 PM, sunilraj.kiran
<sunilraj.kiran at kcubeconsulting.com> wrote:
> Hello Tim,
>      I am working on the ticket https://trac.osgeo.org/qgis/ticket/2974 .
> The ticket deals with Attribute search, as  there can be three ways of NULL
> searches were possible.
> i.e   1) searching records with NULL values.
>        2) searching records containing NULL as text string.
>        3) Both
>          The above ticket can be fixed by designing a New Widget displaying
> the above options. If the user has entered NULL in the Search string Edit
> box in the attribute table dialog the particular Widget could Pop up to ask
> user’s choice and the result will display the selected records.
> I have attached two screenshots containing two designs for the particular
> Pop up Widget. Can you please have a look at it and let me know whether this
> suggestion is fine or not?
> Regards,
> Sunil
> From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> Sent: Thursday, January 13, 2011 5:21 PM
> To: sunilraj.kiran
> Cc: Jürgen E. Fischer; qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] RE : Debugging QGIS Bugs
> I believe he is talking about null as in no value. This is the kind
> of behavior that I would use.
> 2011/1/13 sunilraj.kiran <sunilraj.kiran at kcubeconsulting.com>
> Hello Everyone,
>      I am working on the below ticket. While proceeding I came through with
> a question, whether we should deal the particular bug either with "null"
> which means no value or with "null" which is a text null ?
> Regards,
> Sunil
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Visit http://linfiniti.com to find out about:
 * QGIS programming services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
