FW: [Qgis-developer] RE : Debugging QGIS Bugs
Andreas Neumann a.neumann at carto.net
Tue Jan 18 07:33:33 EST 2011
 I'd rather prefer to have this as a setting somewhere instead of being
 interrupted in the search by a popup. Just as in web applications, in
 regular applications popup windows should be avoided, if possible.
 I think this could be a setting/option that should be saved in the
 project file, either
 * per dataset
 * per column
 * project setting
 * global setting (already possible now)
 In one of the recent check-ins from yesterday or today, Jürgen Fischer
 added a setting in "Options" --> "General" --> "Representation of NULL
 values" which allows for arbitrary strings to mean "NULL". One can use
 NULL in his own language, or as a number -9999, or whatever one likes.
 I think you should use this setting for the NULL searches and don't ask
 the user each and every time he is searching for NULL. This setting
 doesn't change frequently, so I think it is ok as a global setting, or
 maybe also a per project or dataset/column setting which can overwrite
 the global setting.
 Just my two cents,
 Thanks for working on it!
 Andreas
 On Tue, 18 Jan 2011 14:18:40 +0200, Tim Sutton wrote:
> Hi
> Radio button one is probably more appropriate in this case.
> Regards
> Tim
> On Tue, Jan 18, 2011 at 1:17 PM, sunilraj.kiran
> <sunilraj.kiran at kcubeconsulting.com> wrote:
>> Hello Tim,
>>      I am working on the ticket
>> https://trac.osgeo.org/qgis/ticket/2974 .
>> The ticket deals with Attribute search, as  there can be three ways
>> of NULL
>> searches were possible.
>> i.e   1) searching records with NULL values.
>>        2) searching records containing NULL as text string.
>>        3) Both
>>          The above ticket can be fixed by designing a New Widget
>> displaying
>> the above options. If the user has entered NULL in the Search string
>> Edit
>> box in the attribute table dialog the particular Widget could Pop up
>> to ask
>> user’s choice and the result will display the selected records.
>> I have attached two screenshots containing two designs for the
>> particular
>> Pop up Widget. Can you please have a look at it and let me know
>> whether this
>> suggestion is fine or not?
>> Regards,
>> Sunil
>> From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
>> Sent: Thursday, January 13, 2011 5:21 PM
>> To: sunilraj.kiran
>> Cc: Jürgen E. Fischer; qgis-developer at lists.osgeo.org
>> Subject: Re: [Qgis-developer] RE : Debugging QGIS Bugs
>> I believe he is talking about null as in no value. This is the kind
>> of behavior that I would use.
>> 2011/1/13 sunilraj.kiran <sunilraj.kiran at kcubeconsulting.com>
>> Hello Everyone,
>>      I am working on the below ticket. While proceeding I came
>> through with
>> a question, whether we should deal the particular bug either with
>> "null"
>> which means no value or with "null" which is a text null ?
>> Regards,
>> Sunil
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
