[Qgis-developer] A roadmap to QGIS 2.0
Werner Macho
werner.macho at gmail.com
Wed Jan 19 06:11:41 EST 2011
sure - but you are a dev ..
think of a normal user ..
i have a lot of people working here in my company that install a
program and are afraid of going to the next version because "probably
something might not work as expected" or "buttons are placed
elsewhere" ..
I also do not have such problems - but thats because i am used to test
new software every day ..
but i definitely can understand the view of a "normal or new" user ...
It was just the suggestion that we surely should go on with
development but also provide the user with a known interface and a
known version number called "stable"
On the other hand - I can already hear the rants "plugin xxx is not
working in my qgis" when the plugin is meant to run in a higher
version .. but thats one of the things we would have to deal with ..
kind regards
Werner
On Wed, Jan 19, 2011 at 11:36 AM, <luca_manganelli at comune.trento.it> wrote:
> qgis-developer-bounces at lists.osgeo.org scritti il 19/01/2011 11.30.15
>> You are definitely right!
>> I agree that we probably should do the same as we did with 1.0 (with
>> less success) and call 2.0 a "Long Term release".
> 1.0 was almost abbandoned in favour of more stable 1.2/1.4.
> So I think it will happen when 2.2/2.4 will be out.
> If a 2.0 project can be opened with QGIS 2.2, I don't see why I should stay
> at 2.0 without all bugfixes of 2.2.
> Qgis-developer mailing list
