[Qgis-developer] dxf read
Jürgen E. Fischer jef at norbit.de
Wed Jan 26 06:31:52 EST 2011
On Wed, 26. Jan 2011 at 10:26:11 +0100, Marco Hugentobler wrote:
> > but I'd expect OGR to present a
> > layer list (organized by DXF layers and geometry types)
> The layers are not organised by geometry type (this is also true for other
> OGR formats). Maybe, from QGIS side, it needs a similar approach as for the
> PostGIS tables without entries in geometry_columns?
Yes, we could allow to set a geometry type and skip all features with a
different geometry type or better return an empty geometry instead - to get the
feature count right.
Or we could extent the layers to have three renderers - one for each geometry
type.  We recently added NoGeometry - so I figure we know where to look now.
That way we could also get rid of that PostGIS filter trick (ugly because you
could remove the filtering subset string).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
