[Qgis-developer] Convert v1.7 project files to v1.6?
uk52rob uk52rob at yahoo.co.uk
Fri Jul 1 06:54:46 EDT 2011
Barry / Ramon,
Thanks for the advice.
I have looked into the project files using TextPad. I noticed a few
differences between a different 1.6 file and the 1.7 file, but after
changing these, it still crashes.
With there being over 600 lines of XML in the project, and a large workload
on my desk, I think i'll just have to re-create the projects, it will be
much faster.
Kind regards,
Rob
-----Original Message-----
From: b.rowlingson at googlemail.com [mailto:b.rowlingson at googlemail.com] On
Behalf Of Barry Rowlingson
Sent: 01 July 2011 10:59
To: uk52rob
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Convert v1.7 project files to v1.6?
On Fri, Jul 1, 2011 at 10:41 AM, uk52rob <uk52rob at yahoo.co.uk> wrote:
> All,
> I have now moved back to v1.6 after the many issues faced with v1.7, and I
> support Andreas Neumann's e-mail of yesterday.
> The issue I am now up against is that v1.6 cannot open v1.7 project files,
> it simply crashes. Project files which were not opened and saved in v1.7
are
> still fine.
> I have been into v1.7 on another windows computer, but there is no option
to
> save the project as a backwards compatible file. Perhaps this can be an
> option for the future?
> If anyone has any solutions to this, I would be grateful. Otherwise, I
will
> have to re-create the projects manually in v1.6.
 Not got a full solution, but you might get some joy from editing .qgs
files manually - they are XML and so can be edited using a text editor
(eg emacs on Unix, notepad++ on Windows). I've done some comparisons
by loading 1.6 files into 1.7 and saving, then diffing the results.
Apart from the change of version in the header there's a few tags that
appear in 1.7, and some other differences. If your projects aren't
that complicated you could possibly manually edit a 1.7 file back to
1.6 compatibility.
 Hope that's not too impossible or too obvious. I suspect saving as an
old version from 1.7 might be difficult given new functionality in
1.7. But if people are finding 1.7 broken.... yikes...
Barry
