[Qgis-developer] Re: Fwd: [Qgis-user] QgsVectorLayer causes "Failed to load" error
Tim Sutton lists at linfiniti.com
Thu Jul 7 06:19:17 EDT 2011
Hi
On Thu, Jul 7, 2011 at 11:52 AM, leonidas <leonidas_liakos at yahoo.gr> wrote:
> I remove libqgis_core.so.1.6.0 but the problem still exists...
Did you remove all other 1.6 related libs? Probably you should be
doing it with your package manager....
Use ldd to check that all your libs are correctly pulled in e.g.
ldd /usr/share/qgis/python/qgis/core.so
You should see references to the 1.7 libs there for qgis related stuff....
Regards
Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fwd-Qgis-user-QgsVectorLayer-causes-Failed-to-load-error-tp6482726p6557746.html
> Sent from the qgis-developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
