[Qgis-developer] qgis mobile configure log
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jul 11 02:53:04 EDT 2011
Hi Marco
Unfortunately, I don't have experience in cross-compiling with cmake.
The following page contains some information about cross compiling for arm.
Don't know if it can be useful.
http://www.paraview.org/Wiki/CMake_Cross_Compiling
Regards,
Marco
Am Montag, 11. Juli 2011, 00.30:11 schrieb Marco Bernasocchi:
> Anybody sees anything familiar here? (the QT_QTUITOOLS_INCLUDE_DIR
> problem is due to necessitas not having QTUITOOLS yet), what about the
> others like the openpty one (has o do with CHECK_FUNCTION_EXISTS(openpty
> NEED_LIBUTIL) )?
> any hint is welcome
> ciao Marco
> -- SWIG is not found
> -- The C compiler identification is GNU
> -- The CXX compiler identification is GNU
> dpkg-architecture: warning: Unknown gcc system type
> arm-linux-androideabi, falling back to default (native compilation)
> -- Check for working C compiler:
> /opt/android-9-toolchain/bin/arm-linux-androideabi-gcc
> /opt/android-9-toolchain/bin/arm-linux-androideabi-gcc -- works
> -- Detecting C compiler ABI info
> CMake Error: Could not COPY_FILE.
>    OutputFile: ''
>      copyFile:
> '/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_C.bin'
> Unable to find executable for try_compile: tried
> "/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/cmTryCompileExec" and
> "/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec"
> and
> "/home/marco/dev/qgis/build/CMakeFiles/CMakeTmp/Development/cmTryCompileExe
> c".
> -- Detecting C compiler ABI info - done
> CMake Error at
> /usr/share/cmake-2.8/Modules/CMakeDetermineCompilerABI.cmake:40 (FILE):
>    file STRINGS file
>    "/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_C.bin"
>    cannot be read.
> Call Stack (most recent call first):
>    /usr/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:71
> (CMAKE_DETERMINE_COMPILER_ABI)
>    CMakeLists.txt:7 (PROJECT)
> -- Check for working CXX compiler:
> /opt/android-9-toolchain/bin/arm-linux-androideabi-g++
> /opt/android-9-toolchain/bin/arm-linux-androideabi-g++ -- works
> -- Detecting CXX compiler ABI info
>    OutputFile: ''
>      copyFile:
> '/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_CXX.bin'
> and
> c".
> -- Detecting CXX compiler ABI info - done
> CMake Error at
>    file STRINGS file
> "/home/marco/dev/qgis/build/CMakeFiles/CMakeDetermineCompilerABI_CXX.bin"
> cannot be read.
>    /usr/share/cmake-2.8/Modules/CMakeTestCXXCompiler.cmake:64
> -- Quantum GIS version: 1.8.0 Trunk (10800)
> -- Looking for openpty
> -- Looking for openpty - not found
> CMake Error at CMakeLists.txt:140 (MESSAGE):
>    openpty not found!
> -- Found Proj: /home/marco/apps/qgis-mobile/lib/libproj.so
> -- Found Expat: /home/marco/apps/qgis-mobile/lib/libexpat.so
> -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
> -- Found GEOS: /home/marco/apps/qgis-mobile/lib/libgeos_c.so
> -- Found GDAL: /home/marco/apps/qgis-mobile/lib/libgdal.so
> -- Found Qwt: /home/marco/apps/qgis-mobile/lib/libqwt.so
> -- Looking for Q_WS_X11
> -- Looking for Q_WS_X11 - not found.
> -- Looking for Q_WS_WIN
> -- Looking for Q_WS_WIN - not found.
> -- Looking for Q_WS_QWS
> -- Looking for Q_WS_QWS - not found.
> -- Looking for Q_WS_MAC
> -- Looking for Q_WS_MAC - not found.
> -- Found Qt-Version 4.8.0 (using
> /opt/necessitas/Android/Qt/4762/armeabi/bin/qmake)
> -- Pedantic compiler settings enabled
> -- Debug output enabled
> -- txt2tags not found - disabled
> CMake Error: The following variables are used in this project, but they
> are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the
> CMake files:
> QT_QTUITOOLS_INCLUDE_DIR (ADVANCED)
>     used as include directory in directory /home/marco/dev/qgis/src/gui
>     used as include directory in directory /home/marco/dev/qgis/src/app
> -- Configuring incomplete, errors occurred!
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
