[Qgis-developer] QGIS-MapServer 1.7 GetFeatureInfo problem
Pedro Venâncio
pedrongvenancio at yahoo.com
Mon Jul 11 11:44:39 EDT 2011
Hello Andreas,
Yes, I think this aspect is not the problem, everything is in EPSG:20790 (QGIS project, all layers and the project - and wms layers - as client).
In addition, this same configuration worked without problems before upgrading to version 1.7.
Thanks,
Pedro
----- Original Message -----
Hi Pedro,
Is the CRS (projection, coordinate reference system) set up correctly in the WMS and in the WMS client? Is the QGIS project set up correctly with the CRS?
Andreas
On Mon, 11 Jul 2011 07:19:49 -0700 (PDT), Pedro Venâncio wrote:
> Hello everyone,
> I have a problem in QGIS-MapServer 1.7. The result of Identify is
> blank on QGIS 1.7.
> I found this problem on a clean Ubuntu install of QGIS and
> QGIS-MapServer 1.7. Since I had another machine with QGIS and
> QGIS-MapServer 1.6 running smoothly, I did the upgrade to 1.7 on this
> machine (also Ubuntu) and the same application crashed the Identify
> feature after the upgrade.
> The GetCapabilities continues to show the layers as identifiable
> (queryable = "1"), however QGIS displays the results in white (see
> picture). This happens with both point, polyline and polygon features.
> Can anyone confirm this?
> Thank you!
> Pedro Venâncio
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
