[Qgis-developer] QGIS-MapServer 1.7 GetFeatureInfo problem
Mayeul Kauffmann mayeul.kauffmann at free.fr
Tue Jul 12 18:42:28 EDT 2011
Hi Pedro,
On Ubuntu Natty, I have not been able to use the  ubuntugis packages in
3 machines, but I successfully use a script I posted here to automate
building QGIS 1.7.0 from source:
http://www.qgis.org/wiki/Talk:Building_QGIS_from_Source
Obviously you would need to change
 local_base_path=/your/path ( a subfolder is created below this)
and
"-DWITH_MAPSERVER=False"
If you try this, I'm interesting in knowing the outcome.
Hope this helps; good luck!
Mayeul
Le mardi 12 juillet 2011 à 11:32 -0700, Pedro Venâncio a écrit :
> Hello Marco,
> I tried on several clean Ubuntu and Debian installations (with ubuntugis packages) and always works with version 1.6 and never with 1.7.
> After that I have tested the packages qgis.org/debian (http://www.qgis.org/wiki/Download#Ubuntu) and everything works without problems with version 1.7 (both in ubuntu and debian). Anyone confirms?
> Therefore, I deduce that it could be a problem in ubuntugis packages or in any of its dependencies.
> Best regards,
> Pedro
> PS: Now I have a small doubt, it is possible to define some of the layers published as not queryable (<Layer queryable="0">)? By default, all layers appear as queryable.
> Qgis-developer mailing list
