[Qgis-developer] Fwd: SAGA Interface for QGIS - Weekly report
Camilo Polymeris cpolymeris at gmail.com
Sat Jun 4 10:46:52 EDT 2011
Hello,
This week, I coded a GUI list of modules, sorted by tag (which in the
case of SAGA are determined programmatically), plus the basics of a
'run module' dialog. I have started working on the parameter passing
aspect of the framework.
I also set out to handle class generation for the GUI & installation
of python files from cmake. Being inexperienced in cmake, this wil
require further study & work.
Next week I intend to (as per the timeline), add GUI elements for the
simplest cases of parameters and get the build system working.
A screenshot, links & prior reports are available through [2]
Regards,
Camilo
> [1] https://github.com/polymeris/qgis/wiki/QGIS-Processing-Framework
> [2] https://github.com/polymeris/qgis/wiki/Reports
> [3] https://github.com/polymeris/qgis
