[Qgis-developer] Qt build for QGIS source
Charlie Sharpsteen chuck at sharpsteen.net
Sun Jun 5 17:53:09 EDT 2011
The Homebrew formulae may be of help:
For Qt:
    https://github.com/mxcl/homebrew/blob/master/Library/Formula/qt.rb
For Qwt (note that you may need to downgrade Qwt from 6.0.0 to 5.2.1 to
compile QGIS):
    https://github.com/mxcl/homebrew/blob/master/Library/Formula/qwt.rb
For QGIS (unreleased and under active development):
    https://github.com/Sharpie/homebrew/blob/qgis/Library/Formula/qgis.rb
The formula files are just Ruby scripts that calculate the required
arguments to configure, cmake, etc and then run the commands.
-Charlie
On Sun, Jun 5, 2011 at 1:22 PM, Mars Sjoden <aurorageomatics at gmail.com>wrote:
> Cool! did not know that!
> Yah, both arch's x86_64 and i386 installed as universal.
> I'll keep grinding away at it.
> I better keep notes this time!
> Thanks
> On Sun, Jun 5, 2011 at 12:31 PM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
>> Qt Cocoa should have 64bit for all the Qt frameworks.  You can check a
>> framework archs with:
>> file /Library/Frameworks/QtSvg.framework/QtSvg
>> I don't know why it's failing on qwt designer.  It's not needed by QGIS
>> really.  Try disabling it in the qwtconfig.pri - comment out the line to add
>> it to the config.
>> On Jun 5, 2011, at 1:50 PM, Mars Sjoden wrote:
>> > Yes of course William, a very incredibly helpful resource.
>> > I likely am unable to follow instructions correctly, as I am finding
>> (and remember in my case) there were (are) special steps that I need to take
>> to build all the pre-req's... Have you ever tried building with two kids
>> hanging off your arms ^_^ ha ha!
>> > There maybe something I am doing that is causing all our Intel Core 2
>> Duo's to cause troubles with QGIS.
>> > for instance:
>> > ld: file not found: QtSvg.framework/Versions/4/QtSvg for architecture
>> x86_64
>> > collect2: ld returned 1 exit status
>> > make[1]: *** [plugins/designer/libqwt_designer_plugin.dylib] Error 1
>> > make: *** [sub-designer-make_default] Error 2
>> > Are these errors normal when making of QWT?
>> > QtSvg for 64bit is missing, so this would suggest that I may have
>> downloaded the wrong Qt libraries for SnowLeopard?
>> > Perhaps there is no 64bit QtSvg available?
>> >  I downloaded the:
>> > Cocoa: Mac binary package for Mac OS X 10.5 - 10.6 (32-bit and 64-bit)
>> http://qt.nokia.com/downloads/qt-for-open-source-cpp-development-on-mac-os-x
>> > Thanks for the help, these issues so incredibly trivial for you I
>> understand.
>> > Mars
>> > On Sat, Jun 4, 2011 at 5:00 PM, William Kyngesburye <
>> > It's all in the INSTALL document in the QGIS source.
>> > On Jun 4, 2011, at 5:38 PM, Mars Sjoden wrote:
>> > > Thanks,
>> > > Tried the SDK download, but throws some errors when building some of
>> the dependancies (pyqt I think).
>> > > Simply installing the libs seems to work so far, …must install to
>> allow for dynamic libs?
>> > > I need to remember to write down this process for myself!
>> > > Sent from the  MarsPhone
>> > > On 2011-06-04, at 11:07 AM, William Kyngesburye <
>> > >> Don't compile Qt from source, just download the framework installer.
>>  They also have debug libs as a separate download (it adds to the
>> frameworks).  For most purposes the "Qt Libraries" downloads are enough, but
>> if you need the dev tools, like Qt Designer and the Qt IDE you need the
>> larger Qt SDK.
>> > >> Looks like they changed their download page layout a bit - the
>> SDK/Library section used to be side by side, now they're sequential and you
>> need to scroll down to find the Library links.
>> > >> On Jun 4, 2011, at 12:43 PM, Mars Sjoden wrote:
>> > >>> Hello,
>> > >>> I am on my wife's computer (Snow Leopard) and am trying to remember
>> if I need to build Qt libraries as a static or dynamic library?
>> > >>> I seem to remember dynamic is preferred for dependancies but also
>> seem to remember that the auto-download/build installer for Qt for Mac
>> builds the libraries as static?
>> > >>> What is the smoothest download for Qt (and debugging) that I should
>> be using for Mac?
>> > >>> Thanks!
>> > >>> a non-developer hack.
>> > >>> _______________________________________________
>> > >>> Qgis-developer mailing list
>> > >>> Qgis-developer at lists.osgeo.org
>> > >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > >> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> > >> http://www.kyngchaos.com/
>> > >> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
>> fighting, and all for things that the beasts of the jungle would not deign
>> to possess - money to purchase the effeminate pleasures of weaklings.  And
>> yet withal bound down by silly customs that make them slaves to their
>> unhappy lot while firm in the belief that they be the lords of creation
>> enjoying the only real pleasures of existence....
>> > >> - the wisdom of Tarzan
>> > All generalizations are dangerous, even this one.
>> "The beast is actively interested only in now, and, as it is always now
>> and always shall be, there is an eternity of time for the accomplishment of
>> objects."
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110605/bedc9242/attachment-0001.html
