[Qgis-developer] Re: dealing with "long" primary keys
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Jun 7 09:55:10 EDT 2011
Hi Jürgen
> If that's ok, I'd revisit the issue.
+1. Between 1.7 and 2.0 is the best time to introduce such changes.
Regards,
Marco
Am Montag, 6. Juni 2011, 17.24:00 schrieb Jürgen E. Fischer:
> Hi Andreas,
> On Mon, 06. Jun 2011 at 16:21:34 +0200, Andreas Neumann wrote:
> > If this patch still works I would vote for applying it to trunk. It is
> > sad that one cannot load data with long id integer primary keys. OSM is
> > certainly an important enough community or data source to justify the
> > application of this patch.
> > Or would it require a lot of additional work besides applying and
> > reviewing the patch?
> That's the question.  IIRC the reason why I didn't apply the patch.
> Currently we don't have a feature id type so everything that is an int
> might actually be a feature id - that needs to by changed to 64bit.
> And that not only for variables and parameters, but also for signals and
> slots. The former case would be picked up by the compiler, but the latter
> case won't. So that needs quite an amount of testing.
> The patch is likely to not apply cleanly anymore, but even if it did -
> there might be new signals that it doesn't apply to yet.
> So that probably means we'd apply it, break qgis here and there, test and
> train to file redmine issues, git some more experience and end up with a
> fixed qgis that has support for 64bit keys.
> Jürgen
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
