[Qgis-developer] Re: SAGA Interface for QGIS - Weekly report
Camilo Polymeris cpolymeris at gmail.com
Fri Jun 17 19:39:06 EDT 2011
This week the Framework's design saw many changes. Julien has started
to experiment with interfacing it to the Orfeo Toolbox, and from the
ensuing discussion the conclusions of creating a separate plugin for
the framwork's gui, sort of a "module manager", now called
processingplugin and removing some unnecessary classes were drawn.
These things were implemented.
Also, a model-view interface will be used for the module list.
Some bugs were also fixed. A few new parameter types introduced.
(String, Boolean, Choice). The UI has imporved a bit.
Apropos, no screenshot this week, but, the good news is you can see
for yourself how it is coming along, since the **very experimental**
plugins are now available through the faunalia.it repo[1]. Note that
you have to install "processingplugin" for the SAGA plugin to work.
Many thanks to Giuseppe & Paolo for their help.
Any comments welcome!
Next week I hope to catch up with validators, and move the module list
to model-view.
As always, past reports are available at the project's wiki.[2]
Regards,
Camilo
[1] http://www.faunalia.it/qgis/plugins.xml
[2] https://github.com/polymeris/qgis/wiki/Reports
