[Qgis-developer] Printing 25k raster maps
uk52rob uk52rob at yahoo.co.uk
Thu Jun 23 06:07:48 EDT 2011
Hi Marco,
Interestingly, I have done some research on this last night and this
morning, and it appears to be an issue with the rendering of the print.
For some reason, the 25k raster layer is only filling the top 1/3 of the
print, with the 250k raster layer underneath then becoming visible for the
other 2/3.
I have created a new project, put the 25k raster in, created a new print
composer and printing the map alone works fine.
However, I have just created my current project again from scratch to ensure
no project file errors occurred when moving from 1.6 to 1.7, and the same
happens!
If I remove the underlying 250k raster layer, the lower 2/3 of the print
becomes blank, with only the vector shapefiles displayed.
When I export this to a PDF, it turns out fine, but you can see Acrobat
Reader rendering the first 250k layer, then the overlaying 25k layer, so I
wonder..
I printed another project fine, so I just don't know what to do with this
one!
Cheers,
Rob
-----Original Message-----
From: Marco Hugentobler [mailto:marco.hugentobler at sourcepole.ch]
Sent: 22 June 2011 16:38
To: qgis-developer at lists.osgeo.org
Cc: uk52rob
Subject: Re: [Qgis-developer] Printing 25k raster maps
Hi Rob
Just tested here and I can print my 1:25k maps here (geotiff though).
Do you have the possibility to make an example available (or send it to me
privately)? Please open a bug ticket with exact description of steps (e.g.
if
you print to printer, export as pdf, export as image, operating system
used).
Regards,
Marco
Am Mittwoch, 22. Juni 2011, 17.29:30 schrieb uk52rob:
> Hi All,
> Since changing to v1.7 Wroclaw, I can no longer print 1:25k raster mapping
> data.
> The data I have is currently in PNG format, and worked fine in v1.6
> Copiapo. It displays fine in the QGIS main window, but will not display in
> the print composer or actually print onto a page.
> I have tried re-downloading the raster file, re-importing it, starting a
> new project with it, re-installing QGIS, and even trying it on another PC,
> but all have the same problem.
> Has anyone else come across this? I desperately need a solution, otherwise
> i'm going to have to go back to v1.6, which is a real shame.
> Thanks,
> Rob
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
