[Qgis-developer] QGIS for Water
Marco Hugentobler marco.hugentobler at sourcepole.ch
Fri Jun 24 03:10:30 EDT 2011
Hi Werner
> and a tin creation
> algorythm which is not ignoring breaklines is also a big point for me.
The interpolation plugin provides constrained delaunay triangulation. You can
add layers and mark them as breaklines or structure lines.
Though the numerical robustnes of the code might not be good enough for
enterprise usage (was developed as part of a phd project).
Regards,
Marco
Am Freitag, 24. Juni 2011, 08.40:24 schrieb Werner Macho:
> Hi there!
> I am very interested in this topic too..
> I played around with ANUGA a bit and I use SMS very often ..
> To be honest since Bricsys released their BricsCAD for linux SMS is the
> last software that keeps me bound to Windows.
> But the 3D Component is still missing in QGIS and a tin creation
> But I like the idea of probably using QGIS for modeling ..
> I also like to integrate the GRASS topmodel for hydrology  - we'll see
> if i am able to do this ;)
> regards
> Werner
> On 06/23/2011 09:07 AM, Saber Razmjooei wrote:
> > Hi there
> > I reckon it will be great to have a set of plugins for hydrology and
> > hydraulic modelling in QGIS.
> > To develop a new hydraulic engine for QGIS is not an ideal and we will
> > be re-inventing the wheel. So, the ideal situation is to take an
> > existing tool and use QGI to pre-process or post-process the
> > inputs/outputs.
> > Most of the hydraulic/hydrology model I have come across are for Windows
> > only, which is not ideal.
> > The only one which is very powerful and really multi-platform is AnuGA
> > http://sourceforge.net/projects/anuga/
> > AnuGA can be used for modelling: coastal, fluvial, surface water and
> > urban drainage system.
> > We have developed a plugin for QGIS so that you can prepare your model
> > GIS files (boundary files, mesh, etc). It is a bit out of date and
> > requires lots of tweaking.
> > http://sourceforge.net/projects/anuga-gai/
> > Will be good find a fund from those who are interested and develop this
> > further. We have several ideas to improve the plugin further (mesh
> > editor, result viewer, etc) but extremely busy atm.
> > Cheers
> > Saber
> >> Da: "Alister Hood"<alister.hood at synergine.com>
> >> A:<qgis-developer at lists.osgeo.org>
> >> Oggetto: [Qgis-developer] QGIS for Water
> >> Data: gio, giu 23, 2011 00:23
> >> Hi,
> >>> Date: Tue, 21 Jun 2011 09:47:36 -0400
> >>> From: Orn?lio Hinterholz Junior<ohjrr2009 at gmail.com>
> >>> Subject: [Qgis-developer] QGIS for Water
> >>> To: qgis-developer at lists.osgeo.org
> >>> Message-ID:<1308664056.1719.3.camel at dtti01>
> >>> Content-Type: text/plain; charset="utf-8"
> >>> Hi guys,
> >>> I'd like to know if there is a project for hydraulic modelling using
> >>> QGIS, like InfoWater or WaterGEMS or EPANET???
> >>> Thanks in advance,
> >>> Ornélio Hinterholz Junior
> >>> BRAZIL
> >> Unless there are tools in GRASS relating to this, I think there is
> >> currently only the ghydraulic plugin: "a simple Quantum GIS plugin
> >> that adds a function to calculate economic diameters based on given
> >> flowrates".
> >> Hopefully what you want will be available in the future, as the
> >> ghydraulic homepage does say this:
> >> "Roadmap
> >> GHydraulic should fully integrate the EPANET engine into Quantum
> >> GIS" [1]
> >> But I don't know whether it is being actively developed or not.
> >> Also, the developer of inpPINS (which is a program for converting
> >> shapefiles to and from SWMM input/output files [2]) says that it in
> >> the future is intended to support EPANET as well as SWMM [3].
> >> [1] http://epanet.de/en/ghydraulic/index.html
> >> [2] http://www.mapwindow.org/downloads/index.php?show_details=62
> >> [3] http://www.slideshare.net/rpina/floodsfoss
> >> Regards,
> >> Alister
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
