[Qgis-developer] Problem with select() NOT working on spatialite and shapefile (with Plugin example)
luca_manganelli at comune.trento.it luca_manganelli at comune.trento.it
Fri Jun 24 08:30:56 EDT 2011
on  http://hub.qgis.org/issues/3987
I've attached a sample plugin that permits an user to make a selection on
any feature, so you can test it yourself.
It demonstrates that QgsVectorLayer.select() function works only on PostGIS
layer,
on RasterLite / ShapeFile layers  you cannot select polygons.
Select() is broken on 1.7, while 1.6 worked perfectly.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110624/82e55be2/attachment.html
