[Qgis-developer] Re: python plugin and layer properties window
Michael Pfeiffer Michael.Pfeiffer at bd.so.ch
Thu Jun 30 05:29:00 EDT 2011
Hi Marco,
>> What do you exactly mean with composer window class?
>> QgsComposerView or QgsComposerView.composerWindow() = QMainWindow?
>As the signal would be needed for Plugins, I thought about adding it to
>QgsComposerView class. Do you need any additional information coming with
the
>signal (e.g. which composerview it is)?
Not at the moment.  But I think knowing which composerView it is could be
useful some day.
So am I understanding you right that this is sth for the core and not for
solving in the PlugIn?
>> And is it right that the Map Composer is automatically opening after
>> calling /self.iface.actionPrintComposer().trigger()/
>> so using the composerWindow() isn't necessary?
>composerWindow() is useful whenever you need to get a pointer to the window
>(trigger() only opens a new one but then you don't have a pointer).
thx
Regards,
Michael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/python-plugin-and-layer-properties-window-tp6383931p6532468.html
Sent from the qgis-developer mailing list archive at Nabble.com.
